Road Racing - How is your FIXED BACK race seat mounted?
FASTFATBOY
09-16-2011, 09:00 AM
I am looking at putting Corbeau FX1's in my car. The wide version on the drivers side.
Pics and info on how your fixed back seat is mounted please.
SIK02SS
09-16-2011, 09:30 AM
with Cobra brackets on a slider using factory bolt holes, don't have pics. nothing really rocket science about it, I bet something as simple as Arizen brackets/slider would work..
mitchntx
09-16-2011, 10:16 AM
http://lawmotorsports.net/Pics/94%20Teal%20Formula/web/94TealForm42.JPG
http://lawmotorsports.net/Pics/94%20Teal%20Formula/web/94TealForm41.JPG
Four 1/4-20 grade 8 bolts with heavy fender washers.
Bolts into a section of 1 1/2" square tube with 1/4-20 threaded inserts welded into one side.
Square tubes are welded to the factory seat channels on the floor.
On an aluminum seat, drill through the seat and mount.
With a composite seat, use the 90* angle side mounts.
FASTFATBOY
09-16-2011, 11:28 AM
If I bought an aluminum seat, I am looking at a Ultrashield Rallysport seat, and Corbeau brackets....can I bolt the seat directly to the bracket with a plate in the bottom of the seat to spread the load?
Or does it need to be mounted with the side plates?
mitchntx
09-16-2011, 12:57 PM
I use fender washers to spread the load. No need for a plate.
An aluminum seat will need a back brace braced against a cross bar.
Only FIA rated seats don't require a back brace.
SIK02SS
09-16-2011, 01:04 PM
Correct me if I'm wrong Mitch, but I heard this year that NASA (and some other HPDE places following the heard) are requiring back braces on all fixed back seats put into a street car? Have you heard anything about this?
mitchntx
09-16-2011, 03:59 PM
No, I haven't heard that. but it wouldn't surprise me.
The unsupported upper section sees probably 90% of the G-Forces in an impact.
