Help me Identify this Cam
Old 09-16-2011, 01:05 PM
ryle's Avatar
Default Help me Identify this Cam
I just bought a "stock short block" in an auction on Ebay. I got the engine home and right away I could tell that it had been rebuilt so I looked a little farther into it and after comparing the cam I pulled out of it to my stock Cam, it appears bigger. I can't find this part number anywhere. I think it's a GM cam but not sure. This number was stamped on the back of the cam:
0964
4 19
8244
Anyone care to shed some light on the subject?
Old 09-16-2011, 04:48 PM
2xLS1's Avatar
1997-1999 Corvette
Lift E/I .479/.472
Dur @.050 207/199
LSA 117
Timing 113/121
Part Number 12560964
Old 09-16-2011, 08:45 PM
ryle's Avatar
Thank you. Just the information I was looking for
Old 09-17-2011, 03:39 AM
chrisfrost's Avatar
You might want to measure the base circles of the lobes to make sure it has'nt been reground . I've seen cams from poeple thru E-bay that were reground and the base circles will be smaller than before the regrind . 1 in particular was advertised as an LS6 cam . Well the lift #'s were close to an 02-04 LS6 but every lobe was a little different , they ranged from .542 to .549 or there abouts . But the base circles were like .075 smaller than an LS6's base circles so to use this cam would have required longer p-rods plus no telling what the duration #'s were . Good luck
Old 10-05-2011, 09:54 AM
HottLS1Z's Avatar
0964
4 19
8244
A bit of usefull information on stock stuff. That motor was most likely from a 98 vette.
http://chevythunder.com/LS1%20compon...e%20Components
Old 10-06-2011, 02:33 AM
ryle's Avatar
Thanx for the link.
Actually came out of 99 vette. looks like 98-99 had the same cam.
Quick Reply: Help me Identify this Cam
