9 inch Questions - What did you wish you had done?
All -
My (5th) 10-bolt has begun making noise - but, it has lasted for almost 3 years behind my M6 turbocharged LT1/4, so I really cannot complain.
However, now that I've decided to 'bite the bullet' and buy a 9 inch, I want to avoid those mistakes others have made when trying to 'save a little money', or due to the fact that they didn't know how critical a particular item would be for a 9 inch rearend.
So, for those who have already purchaed a 9 inch, what (if anything) would you do differently?
Did everything bolt together properly, or was some 'modification' required in order to make it fit / work?
Who did you buy from? Did they provide support or did they disappear after your check cleared? (In other words, who should I use and who should I avoid?)
What 'options' did you purchase, and which one did you wish you had purchased? (Wavetrack?, 35 Splines?, Backbrace?, extra fill and drain ports?)
Can a 9 inch be spec'd out with enough aluminum so that it is not heavier than a 10 bolt?
Can you still get "Mikronited" Ring and Pinion gears for a 9 inch?
Is a new / longer driveshaft required?
(I know - alot of questions, but I only want to buy ONE 9 inch rearend for this car, and I really don't know who to ask other than those members who have already spent their money.)
Thanks in advance!
Thanks in advance!
LS1Tech Premium Sponsor
Can you get Micronited Ring and Pinion gears for a 9 inch?
Things that people wish they would of done later after their build is to add tow loops on their housing. It really does make it easier to strap a car down and does not interfere with anything.
Hope this helps.
I just finished my 9" install yesterday. I'll go ahead and say pay the extra for the drain and fill plugs. I got a drain plug but not a fill port and its a huge pain in the *** filling it from the center section..
I used a stock Ford case with a 31 spline TracLoc and Moser housing and axles. Had I done a bit.more research before I assembled my center section I would have gotten a nodular case and different yoke, but I'm confident it will hold my power
All -
My car may see the track once a year....if that. I went MWC 9, tru-trac with Yukon 3.70's....no backbrace and a 4ch. My needs were simply based on strength, weight and novelty (these things are gorgeous!).....could have easily gone with an S60 and been fine for my needs. Fit like a glove, minor mods to the brake lines due to narrowing 1" per side. Other than that...went right in....installed by myself too!
Additional Info
I'd first consider your choices based on application specific use. More track than street and vica versa... Once that's determined (and your honest with yourself, lol), you can start adding the accessories....backbrace, wave or tru-track, spool, spline #'s, etc. As I mentioned earlier, wish I went with some of the conveniences of fill ports and tow hooks.
I think my 10 bolt's saving grace is that I have only gone on 660 / 1320 runs on my street tires; but I want to change that situation.
What I really want is a light, strong 9 inch that I purchase once and be done with. I want all of my UMI suspension parts to 'fit' and I do not want to find out (halfway thru the installation) that I needed to "Check this box" if I had wanted to use my stock LT1 rear brakes, or "Check this other box" if I actually wanted to <insert your favorite nightmare situation here>.
I don't want any "surprizes" such as: "Yeah, you could have gotten a center section that was 20 lbs lighter - if you had only asked..." - or - "Oh, you needed to buy a different U-Joint, didn't YOU know that!" - or - "Oh yeah, I forgot to mention, you'll need to get a different driveshaft - I can have one to you in three weeks!"
No.
I want to do this once - and I don't mind paying more for the "right" part vs. getting a "deal" that doesn't work (and therefore isn't).
I don't want to get 80% of the info I need - I want tech support that will actually assist me AFTER my check has cleared.
I don't want compatablility issues with my UMI suspension parts.
Finally, I don't want it to break because my stock weight car is "too heavy".
Is that too much to ask?
Before I went FI, I'd upgraded the 10 bolt w/ Strange Axles, a cast Aluminum diff cover and a Mikronited Ring and Pinion gearset. It's been a good rear end prior to adding my Turbo, but now with (as of last week) 13 lbs of boost, I'm sure a "spirited" 1320 foot run on my MT drag radials will grenade it.
No.
No.
When I did my MWC three years ago, I went with the short torque arm which recently gave me problms with breaking loose the tack welded brackets on the chassis. I wish I had dont the long arm early on instead. It is beefier, quieter and produces less clunks and bangs IMO.
