ls1 edit...worthwhile?
SN95 Director
ls1 edit: 550
atap/efi: 200-500
laptop: 300+
bottom line its not cheap. i'd look into hp tuner which is 50 buckss cheaper then edit and comes with a scanner. go to the PCM forum and do some research.
basically a tuning program like edit/hp tuner the sky's the limit on what you can do.
atap/efi: 200-500
laptop: 300+
Thanks. I will do some research. I just got a 99 z w/ a4, pewter, 2.73 gears. Seams to bit tight. Doesn't slap in the morning too much, soo it seams.
