98 WS6 Posi Unit?
Old 09-17-2011, 11:38 AM
98ws6blk's Avatar
Default 98 WS6 Posi Unit?
Does my 98 WS6 have the Auburn or the Torsen?
Old 09-17-2011, 01:24 PM
FirstYrLS1Z's Avatar
From the factory production line,98s' and earlier got Auburn,99s' and later got Torsen.
If it's a SLP car,the SLP sheet would indicate if they put a different posi in it as an option after it left the factory and was in their facility.
Old 09-17-2011, 01:38 PM
98ws6blk's Avatar
Cool. That's what I was thinking...so I'd be better off to upgrade to a torsen?
Old 09-17-2011, 04:07 PM
Is there something wrong with your Auburn ?
Old 09-17-2011, 05:47 PM
why87's Avatar
i personally like the torsen a little better, but i never noticed that much of a difference. if yours still makes both tires bite and doesn't make any odd noises i would just leave it.
Old 09-18-2011, 06:38 AM
Auburns typically last 100,000+ miles before the cone clutches wear out and the unit starts acting like a non-posi. The weak point are the 'spiders' which break.
Torsens don't 'wear-out' but have 3 flaws/weak points. 1.the bolts holding the unit together break. 2.the bolts holding the unit together loosen/back-out and then break when they hit something internally in the rearend housing. 3.the flange holding the internal gearset in breaks at its' weak rib points.
Old 09-18-2011, 03:41 PM
98ws6blk's Avatar
Yeah, I think mine is starting to just leave one black mark...what the best way to test if it is indeed not working?
Quick Reply: 98 WS6 Posi Unit?
