Generation IV Internal Engine - Trick Flow Kit vs my LS6 CNC and cam.
Fafonfoe
09-18-2011, 10:13 PM
About to break down my LS2 and pull the Ls6 heads stage 2 and 231/236 cam for a set of trick flows. Has anyone else used these. I got 475 at the wheels with this cam and heads setup and looking to get more thats why I'm changing. Any info on the trick flows would be great. Actual syno results and what not. Thanks
427LS7HCI
09-20-2011, 02:07 PM
Subscribing!
In for results, but my guess would be +10/10rwhp/rwtq peak and under the curve or the CNC LS6s.
Fafonfoe
09-20-2011, 10:31 PM
Only one person for a reply. I know I will get more than that for power. Trick flow are way better than my LS6 CNC heads. Want to know some actual results.
hardcore4sure
09-21-2011, 12:14 AM
If you got 475rwhp That's a pretty good number for that sized cam, even with Trickflows. I dont know of alot of cars hitting much more than that with a medium sized cam, or big ones for that matter. I think 427LS7HCI is right about 10hp/10tq at peak ,but probably a fatter curve. It would be a lotta work and $ and no guarantee they will be that much better. What stage 2 LS6 heads are you running now? Sometimes you gotta figure if it ain't broke don't fix it.
cowboyup
09-21-2011, 07:55 AM
too much work for 10 under the curve.. and maybe 5-7 on top..
nah...PROCHARGER!!! :secret2:
There is another C6 with exact same setup as mine but it has Trickflow 235's on it and I made more.. I'd leave it and save for a blower..:cheers:
Jimbo1367
09-23-2011, 05:56 PM
Who is porting (vendor) the LS6 heads? I just picked up a set of 243s and plan on having TEA work them over..
TrickFlowTech
09-27-2011, 08:00 AM
You have a good set of heads there. Using our heads you may see 10-15 hp peak over what you already have.
