Help need Bushings
Help need Bushings
So the rubber bushings in the back of the car are going one is almost gone and the other is already making a squeaking noise. Took it to a place said couldn't find one without a spring in the kit. The springs are fine I don't want to spend more money then I have to. To make it clear its the back of the car the bushings under the springs before the spring meets the metal of the car, not sway bar bushings or anything else. If anyone can help with a link to the part im looking for or something else would be greatly appreciated. Thanks in advance.
oh it's a 2002 FIREBIRD FORMULA btw Thanks again
Some people here remove the coil spring rubber "donuts" and simply place a length of heater hose on both ends of the coil springs - this lowers the rear end about 1" - some guys like this mod, others do not. (A search will help with this topic).
rear spring isolators? the things in this link? https://ls1tech.com/forums/9970789-post259.html
the heater hose mod is this: https://ls1tech.com/forums/suspensio...ors-guide.html
You're sure the squeaking is coming from the isolators?
