WTT 4L60E stage 2 for T56
Category: Drivetrain
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): CA
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
I have a 4L60E Level 2 and it is still under warranty (will transfer) and only has 4k on it and a 3600 Yank Stall everything else is stock
I dont have a time line on the swap so if your not ready right now we can set up a deal.
ALL PARTS ARE STILL IN CAR
4L60E Level 2 Transmission
• Hardened pump rings
• Servo D ring kit instead of Teflon
• New Accumulator Pistons
• Modified Pump Assembly
• Oversized Boost Valve
• High Quality Overhaul Kit, Frictions and Bushings
• Xtreme Transmissions Shift kit
• Borg Warner dual cage 29 element Input Sprag
• Corvette 2nd gear Servo kit
• Wide rear sun gear bushing
• Heavy duty sun gear shell “The Beast”
• High energy 2-4 Band
• High Energy 7 friction clutch pack with full thickness Kolene Steels
• Teflon Pump Bushing and Extension Housing Bushing
• Built with Performance Tolerances and Lube Modifications
