11 Second Club - question ?
View Full Version : question ?
ruck98
09-20-2011, 12:57 AM
My current.set up is a 98z28 gm hot cam LT ceramic coated headers true dual exhaust 3500 circle d stall 3.73.richmond gears, slp lid do u guys think that will be enough to get me into the 11s i do plan on running et streets
LS1TA_956
09-20-2011, 01:23 AM
Can u post a video on the idle on the idle of.the hot cam i want it.too but wana hear how it sounds first. And are you tuned?
zracer323
09-20-2011, 11:04 AM
Depends on the 60' and the DA. With some good weather it is definitly possible. How much does the car weigh?
ruck98
09-21-2011, 12:49 AM
Pretty much factory weight back seats and spare tire are removed
lemons12
09-21-2011, 01:11 AM
Possible? Yes. Likely? No.
Weather will play a large roll. I don't think you will have the 60' for it, you don't make enough power to make up for the lack of 60'.
I'll say 12.2.
Edit: it is a z28 however which weighs a bit less.... Plus you took a little weight out. I'll give it a 12.1 flat, maybe 12.0. I think it needs a little more converter personally.
