Cost for GT0 Engine swap into LT1 Fbody?? Easy or tough???
Old 09-20-2011, 01:32 AM
WildDr805's Avatar
Default Cost for GT0 Engine swap into LT1 Fbody?? Easy or tough???
Curious if anybody has swapped a GTO motor and tranny into an older Fbody 93-97. Is it difficult and how much work after purchase of engine etc. Considering an LSX build for friend.
Old 09-20-2011, 07:34 AM
LS1Tech Sponsor
psiconversion's Avatar
LS1 or LS2 GTO engine?
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 09-22-2011, 11:28 PM
WildDr805's Avatar
Either one.....LS2 would be nice
Old 09-22-2011, 11:39 PM
JohnS Z28's Avatar
just get a small block chevy crate engine...cheaper than you think.
Old 09-23-2011, 09:46 AM
TEDSgrad's Avatar
I paid $4200 for LS2 complete takeout; maf, all accessories, computer, harness, pedal - 36k miles
$1100 for 4L65E with 24k miles
$995 for harness conversion & computer re-program.
You'll need new exh manifolds or headers - possibly new y-pipe.
Ancillary items add up, too.
Old 09-23-2011, 11:02 AM
LS1Tech Sponsor
Difference between the LS1 and LS2 can get expensive because one is drive by cable the other is drive by wire. If you went DBC, our cost for harness and PCM with tune would be $699 total.
Jon
PSI
__________________
Ebay Store
Old 09-23-2011, 11:51 AM
bczee's Avatar
The block and mounting of a Gen III (LS1) vs a Gen IV engine is the same. What you are recommened to do if swapping into an Early 4th Gen F-Body is to use the mounts, K-Member, Rack/Pinon and other related parts when putting a Gen III/IV into a Early 4th Gen.. The K-member would make things go a lot easier.
If you want step by steps.. research the threads.. or look at a OEM Factory Service Manual cause that is all your doing.. is upgrading to a early to late 4th Gen Power/driveline.
As far as a GTO vs a F-Body.. same basic block. .just swap pan, exhaust and front accessories from a LS1 F-Body and you have a 4th Gen F-Body Gen III/IV configured engine.
Old 09-23-2011, 12:20 PM
merim123's Avatar
unless you're getting that engine for a song, don't go that route without understanding that you'll need:
1) all fbody front accessories (400-800)
2) fbody oil pan (200)
3) fbody ls1 wiring harness and PCM (300-400)
Old 11-24-2011, 08:58 PM
WildDr805's Avatar
So about 1500 on top of motor and trans.....what is usual labor?
Quick Reply: Cost for GT0 Engine swap into LT1 Fbody?? Easy or tough???
