this ebay header on 72 a-body
Old 09-20-2011, 02:37 PM
massen1981's Avatar
Default this ebay header on 72 a-body
Has anyone got this headers to fit the 72 a-body (el camino for this mater)
http://cgi.ebay.com/ebaymotors/LS1-L...item1e668fa615
has to get som headers that is chep and will ship to Denmark, but it sucks if they don´t fit
thanks Mads from Denmark
Old 09-20-2011, 02:52 PM
BanditDave's Avatar
Get yourself a set of Pacesetters for the 4th Gen Fbody...the passenger side fits like it was made for it and the driver side fits well but is a little crooked to the frame rail. Can easily be corrected by adding a bend in the exhaust.
Good luck!
Dave
Old 09-20-2011, 03:02 PM
bczee's Avatar
The are shorty headers.. they usually work on most applications. Usually Full length header are were you can get into some trouble fitting them. They are giving you dimensions.. so. if you can used them with your engine in place, you might at least get a ball park look to see if your going to run into issue of clearance. But I would not expect any being Shorties, not really.
The only issue I can see with these is that the headers do exit/point rearward a lot. if you moving the engine backward in the engine bay. The Firewall may come into play.?? (maybe ?).
But No I cannot comment on these. Suggest you use ebay messaging services to ask question.. Denmark is a bit of a costly expense on shipping...
BC
Old 09-21-2011, 05:37 AM
massen1981's Avatar
I have askéd the ebay seller, and no luck on the fitment.
and yes denmark is a pain to get parts to.
i have to pay it all 2 times before i get the parts
