4K on T brake on a 3600 stall will it hurt it?
On a high end billet converter will it bend the vains or do any other damage if you take it past the stall speed on the Trans brake? My billet converter goes to 4000 and builds 8lb's boost on the brake, is that a problem or should I set up a 2 step to limit it to 3600?
If it is a billet piece then it has good internal components. Who built it?
If they tig welded each fin at every location that could and should be welded then you won't hurt it. Torque converter stall speeds are not an exact science gang. even the best of the best builders will tell you they can only get it close to the desired stall speed the first time out. From there it's like any other component of the race car... it needs to be fine tuned. Meaning, if it isn't stalling at the correct rpm then it will need to come out and be sent back to the builder for some tweaking.
Now, the real question how does the car perform with that converter? Was that converter built for your specific application or did you get it used from someone else?
g
g
g
g
Yes to a point, but it's possible to bend the vains on the stator, I'm just not sure what that point is, I'm asking for a little hand holding here it's new territory.
The stator fin will not bend. If it is an aluminum part, it can crack or shatter. If it is a steel stator, you cannot hurt it. The Typical failure for a staor is for the sprag inside it to grenade.
You will not hurt your converter by taking it past the rated stall speed. However, your car is probably not going to be as fast as it could be if it is blowing through it. What did the converter manufacturer say? Did you call the guy who built it?
The fact that it is going past its rated stall speed does not mean it is damaging it. The stall speed all relative to input torque, and turbo cars are the hardest to build for. So, assuming the converter is built correctly, you are ok. You might want to use a 2 step for consistency and softer launch, that is another story....
Chris
Chris
Chris
Chris
the nice thing about a two step is you can leave however hard the track conditions will hold.
i agree, converter tech has changed a lot, well, more like strength! most of the builders will list a flash stall speed, and it all depends on torque output. there will always be controversy, some list what it will stall on the foot brake, some a flash stall, some on the brake. unless it is custom built to your spec. "if you tell the truth to the builder" it should be close to what you asked for. i learned over the years just not to ask. i just tell them what i have and what i want to do with it. they build it and i smile!
My converter works fine and as I get the motor dialed in I'm seeing more torque lower in the rpm, now with some tweeking I've seen 14lb's @ 4500 on the brake.
