Timing Chain broke today, any guesses?
Old 09-20-2011, 08:54 PM
Transam1's Avatar
Default Timing Chain broke today, any guesses?
car was out for tuning because of new converter, was in second gear, pulling at about 5000rpm attempting to make it shift to 3rd (testing 3/4 clutches) and pop! i was not in car, just what builder/tuner told me. timing chain has about 47,000 miles on it....hell my old one had 118,000 with cam and converter and no issues!! Anyways, 9 bent valves on my afr225's, (6 exhaust, 3 intake). what do i need to do as far as timing chain is concerned? ls2 chain? double? stock GM?
Old 09-20-2011, 09:12 PM
joecar's Avatar
Ouch...!!
What harmonic damper do you have...?
Old 09-20-2011, 09:37 PM
Transam1's Avatar
asp 25%
raptr cam
Old 09-20-2011, 09:47 PM
A.R. Shale Targa's Avatar
Dual chains require shimming of oil pump and grinding on front cover for
clearance. Ls2 is a stout piece for most apps.
Old 09-20-2011, 10:34 PM
got-a-ls1's Avatar
asp pulley... not the first time ive heard this killing a timing chain.
Old 09-20-2011, 10:57 PM
Zmg00camaross's Avatar
^^^ really. I never seen any issues
Old 09-21-2011, 10:32 AM
Jared H's Avatar
I'm running that pulley and replaced my timing chain ~90k ... chain looked great when I took it off but was in there for other reasons so just replaced it while there ... LS2 auto. Sounds like just a ls1 chain and bad luck to me.
Old 09-21-2011, 10:38 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The only ones I can recall off the top of my head have been on Corvettes though, not F-bodies.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 09-21-2011, 11:05 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Be willing to wager you have cracked pistons. Time to pull the heads or scope the cyl. When they go **** breaks. Not just the push rods.
LS2 at a minimum.
Old 09-21-2011, 12:22 PM
sscamaroburn02's Avatar
tsp sells a double rollmaster with spacers and everything to bolt right up.
Old 09-21-2011, 02:01 PM
FlamingTA's Avatar
He only has to grind if he is running a melling high volume pump. Anything else should fit ok with the double roller.
The LS2 set should work out great for your setup.
Old 09-21-2011, 07:11 PM
Transam1's Avatar
pistons are good! even with .075 flycuts! might have gotten away with one there!
Old 09-21-2011, 08:38 PM
vettenuts's Avatar
Bingo!!!
Old 09-21-2011, 09:20 PM
SOMbitch's Avatar
The new design Melling's clear the chain.
