Bosch finewire iridium plugs.Wow
I entered the contest for the iridium finewire plugs.Well i recieved them and stuck them in my ls1.Excellent idle and good thru all rpm's.I like these plugs I normally run the ngk.I think I found my new plug.I am not knocking ngk but you guys need to give these a try.Bosch has got a nice plug here.
New ngk plugs.The ngk plugs i pulled out were still fresh.I won these i figured i would try them.I love the ngk plugs.These plugs just seems smoother through the whole rpm range.I know every car likes different plugs.As for my car it likes these plugs.I just want to run these hard to see how long they will hold up.My wallet might get mad at me.
I'd like to see some dyno results of any brand of iridium plugs I've seen 3hp gains from then on old 650twin yamaha motocycles, 3hp doesn't sound like much but when your starting with a 35-45hp motor thats about a 7% gain. But then again I only had to buy 2 of then not 8 and just for the record they were nkg's. I'd like to see some proof of power gained before I'll spend $50 on a set of plugs.
I also found the the bosch ir fine wires on rockauto for $5.53
What problems are people having with bosch plugs? I've used them before on a couple different vehicles including my camaro. I haven't noticed anything strange on any of them. Then again I dont take my car to the track. So I don't know. Just curious.
I've used Bosch plugs in 4 different vehicals over the last 10years usaully platinum2's and never had any problems but next time the T/A needs plugs I'll probably use NKG's unless someone shows some proof of power gains from a set of $50 plugs.
I've run bosch plugs in my DD saturn and wifes DD honda accord. BOTH vehicles needed new plugs after less than 20K miles. My wife's accord wouldn't start on hot days when her car would sit under the sun for a few hours. Those plugs have always been a headache for me personally. My mechanic shares the same opinion so I just went with his suggestion ever since, NGK!
I ran Bosch platinums in my old 73 Chevy p/u with a 350. It liked them, I never had any problems with them. It wasn't till I switched to Autolites that I started having problems...in two different cars. I hate Autolites.
