UMI Performance
09-22-2011, 01:30 PM
UMI Performance Front Lower A-Arms for 1982-1992 Camaro and Firebird
Part #2031
Price - $399.99 per set
UMI Performance is now offering 3rd generation Camaro and Firebird enthusiasts the opportunity to upgrade from their current factory front A-arms to UMI’s light weight and robust tubular design. Introducing UMI’s #2031 Front Lower A-Arms which are assembled with polyurethane bushings, premium ball joints, bump stops and adjustable steering stops. UMI’s A-Arm kit is shipped fully assembled and ready for a direct bolt on installation for all 82-92 F-Body models. This heavy duty design removes 5lbs of front end weight will adding tire clearance and minimizing bushing deflection. Steering radius and tire clearance for aftermarket wheels and tires can now be adjusted using the bolt on aluminum steering stop shims supplied with each A-arm kit. You will have two powder coated colors to choose from of red or black as well as a Delrin bushing upgrade. As with all UMI Performance products, the UMI#2031’s are manufactured, tested and designed in the USA (Philipsburg, PA). The #2031 A-Arms are also competitively priced at $399.99 per set.
Website Link Here (http://www.umiperformance.com/catalog/index.php?main_page=product_info&cPath=6_82&products_id=103)
Part #2031
