5.3 t70 KYTP build thread front mount
well after 2years my car is finally coming together. my goal is to drive to track run a nice mid 10 sec pass and drive it home but will see.
MOTOR
2006 5.3
243 heads
ARP bolts and head studs
ls6 intake
FUEL
twin in tank 255 walbros
8an feed
stock feed is my return
60lb injectors
fast fuel rails
Magna fuel regulator
TURBO KIT
T70 master power
kytp cross over 2.5'
3in down pipe
eBay intercooler
Rps blow off valve 50mm
3in cold side from ebay
[IMG]http://img.photobucket.com/albums/v612/onebadlt1
/01daa3da.jpg[/IMG]
MOTOR
2006 5.3
243 heads
ls6 intake
FUEL
8an feed
60lb injectors
fast fuel rails
TURBO KIT
T70 master power
3in down pipe
eBay intercooler
/01daa3da.jpg[/IMG]
finally got some time to work on the car
working on the twin pump set up
made both pumps fit
going to drill these holes out
inside shot before I drill both holes
made both pumps fit
nitrous383 made this one for me. he sold the design to motovative
http://www.motovativeperformance.com...=product&id=29
I cut mine when i put a walbro in. It helps to keep fuel in the bucket, along with keeping the pump cool. The stock pump (as you likely know) has a pump to pull it in the bucket, then the pump to send it to the engine. Being that you're eliminating that, you need the extra area open to allow fuel to surround the pump. IIRC, i read that the number one killer of walbros is excessive heat. my .02.
