Other things to do when doing a cam install?
So Ive been reading a pretty good bit about doing a cam in the formula. From what ive read when doing a decent size cam you need to do valve springs, retainers, and push rods. Ive also read that you should do a LS2 timing chain and a ported LS6 oil pump when doing the cam. Would it not hurt to do a water pump as well? If so what kind of water pump? Stocker or some sort of aftermarket?
Ok cool thanks for the info. Just making sure I have everything I need. As far as the cam goes im kinda torn between the Tr224/224 or the Trex. Ls1's are new too me as I just got the car recently. Im looking to put down 400whp or more if possible with just a cam and bolt ons. Its a 6 speed car.
Don't be shy with cam. We did a friends car, and with ported and milled crappy 98 heads and a Futral cam along the lines of 232/232 112+4 .600/.600 and put down 410hp with something like 140k miles on the short block.
http://www.fquick.com/garages/Chevro...Z28/1998/8911/
Drove perfectly fine as a dd.
I will disagree. LS2 chain is fine. Also, messing with rod caps can invite trouble as I have read...... Lifters should be fine if motor was well maintained....
My requirements to do a cam job were cam, chain, oil pump, gasket set, and beer. Lol
