where does the blow down pipe go?
Old 03-07-2004, 07:54 PM
pdd
pdd's Avatar
Default where does the blow down pipe go?
on the bottle??
Old 03-07-2004, 07:59 PM
Bad30th's Avatar
Make sure you get the burst pressure disc in there right - they can only be used once.
Bad30th
Old 03-08-2004, 01:32 AM
pdd
pdd's Avatar
thanks for the pic. does it just run inside the car or do u have it piped outside?
Old 03-08-2004, 09:53 AM
Bad30th's Avatar
The tube extends through the bottom of the trunk to outside air space (silicone in a rubber grommet for the tube to extend through).
The idea is it will burst the disc and vent the bottle outside the car if the bottle pressure exceeds ~1200psi (instead of blowing the bottle up inside the car).
Bad30th
Old 03-08-2004, 11:59 AM
93LS1RX7's Avatar
Must be vented outside the vehicle
