Cheap acceptable rubber bushing set?
I need my front passenger side upper control arm bushing replaced, but I think I might as well replace all of them. My front is making a thumping noise and i suspect that its the bushing. What brand is cheap and good? I want a set if possible.
Thanks
Thanks
I like the comfortable ride so I'm going to stick with rubber.
Got a stupid question. Front control arm has upper and lower bushings but does the rear only have lower bushings? There's no rear upper control arm bushing for sale on rockauto that's why I'm asking. Thanks
I'm replacing my front UCA bushing because whenever I turn tight ever slightly, it makes a thumping noise. I took it to wheel works and they said it's the front right UCA.
My question is... Will a defected bushing cause thumping? Hmm I don't know if I can trust wheel works.
I didn't see any reason for this to be happening, but just for grins, I pressed in a set of poly bushings I happened to have, and no clicking..... I kept the polys in place, and installed polys in the a-arm for the other side, and that's what I've had in place for the last year. I have rubber in the lower arm, and poly in the upper.
