EPS (Pat G) 230/234 Dyno & Track Results (UPDATED 10/9)
Old 09-24-2011, 10:50 AM
Camaro Z's Avatar
Default EPS (Pat G) 230/234 Dyno & Track Results (UPDATED 10/9)
I had my car tuned at RPM Speed (WS6Store). Was waiting to post my numbers until I had some track passes under my belt. I'm very happy with the cam, the car feels strong and has a very good powerband. Anyways, here are the results:
Cam specs: EPS 230/234 112+4 LSA .600/.602
Car dyno'd at 385 rwhp 366 rwtq after the cam swap (330rwhp before the cam) peak hp @ 6200, peak tq @ 4700. Ambient temperature was 93 degrees for the dyno run (72 degrees for the bolt-on run). For reference, a cam only C5 Z06 dyno'd 389 on the same dyno.
Took the car to the 1/8th mile last night on BS Street Lites with 26" Hoosier QTPs. This was the best pass:
1.71 60
7.62 1/8th
93.75 MPH
898 DA
(Previously 8.27 @ 87 mph 1.89 60 ft. before the cam)
Limiter is set to 6400 and the car was hitting the limiter just before the traps. Need to bump up my limiter and hopefully get into the 7.50's @ 94-95. Was doing consistent 1.7X 60 fts and the 10-bolt held up great! I'm happy with the results. My suspension is not set up at all for the track, so there is a lot of room for improvement. Hoping for 11.5-11.8 @ 116-118 range in the 1/4 the way it sits. The car is full weight with A/C.
http://www.youtube.com/watch?v=MKfhFl5FIyw
UPDATE 10/9/11
Went to the 1/4 mile track tonight. The air wasn't quite as good as the 1/8th mile runs earlier in this post. However, the car still ran very well and the 10-bolt held up to even more abuse! I need a shift light to hit my shift points better, the factory tach is lagging quite a bit. Anyways, below is the best timeslip of the night (car is still full weight est 3400-3500 lbs):
1699 DA
(Previously 12.8X @ 110 1.91 60 ft. before cam swap)
Old 09-24-2011, 10:59 AM
Latch's Avatar
Nice... I can't wait to get me an EPS cam. Car looks awesome BTW.
Old 09-24-2011, 11:34 AM
DadsZ28's Avatar
Congrats, great times! Love the street lites, what size are they?
Old 09-24-2011, 11:39 AM
Old School Heavy
speedtigger's Avatar
Very nice. Your car looks and runs great. Now for some track video!
Old 09-24-2011, 11:59 AM
Camaro Z's Avatar
Thanks, wheels are 15 x 3.5, 15 x 10
I was at the track by myself so there was no one to take video for me lol. First time I've raced on bias ply tires, had a blast with the 6-speed!
Old 09-24-2011, 12:06 PM
02TransAm/Batmobile's Avatar
Could you break down your mods? 241's or 853's? What brand headers and what is the rest of your exhaust setup? Etc. Etc.
Old 09-24-2011, 12:16 PM
Camaro Z's Avatar
Sure,
Pacesetter 1 3/4" Longtubes
TSP ORY
3.5" Cutout (after the Y)
Stock 241's
Patriot Gold Duals
Stock length hardened pushrods
91 Octane Tune
Old 09-24-2011, 03:29 PM
RoidedSS's Avatar
time for some AI 243's haha nice numbers man
Old 09-24-2011, 04:35 PM
Austinma62's Avatar
Nice, i bet this cam would SCREAM with some ported 243s!
Old 09-24-2011, 04:46 PM
xX-Z28-Xx's Avatar
Sweet car, and great results!
Old 09-24-2011, 08:10 PM
Camaro Z's Avatar
Thanks guys, heads will definitely come in the future.
Old 09-25-2011, 09:40 AM
Hardtop's Avatar
Nice run and mph, you'll run in the 11's easy. I would roll out on the clutch a bit, the 10 bolt probably won't like being beat on too long. I'd set the limiter about ~ 6700. Congrats.
Old 09-25-2011, 11:05 AM
Camaro Z's Avatar
Thanks, and yes that is what I was doing on the launch. Ran it up to 4-5k and slipped it out of the hole. I know I'm living on borrowed time with the 10-bolt, I have an 8.8 build in the works.
Old 09-25-2011, 11:22 AM
*02WS6TURK*'s Avatar
Nice! I almost went with those same specs. My EPS 226/230 makes buttloads of power all over the board. AI 243's are going on this winter.
Old 09-25-2011, 12:50 PM
southpaw0314's Avatar
you have any videos of it after its been tuned?
Old 09-25-2011, 07:08 PM
Camaro Z's Avatar
Updated with tuned idle clip
Old 09-25-2011, 10:07 PM
I'm still trying to piece together my cam build on the same size cam (although it's on a 111+3). I'll be putting on some 243's with a 5-angle valve job soon.
Old 09-25-2011, 10:16 PM
Camaro Z's Avatar
Should do great with some 243's, be sure to post up your results when it's finished. I'll definitely be doing heads in the future.
Old 10-05-2011, 04:56 AM
sayed_000's Avatar
good numbers .. similar to my cam only numbers .. congrats.
Old 10-09-2011, 04:57 AM
Camaro Z's Avatar
Updated with 1/4 mile times
Quick Reply: EPS (Pat G) 230/234 Dyno & Track Results (UPDATED 10/9)
