strkt_&_blwn
09-24-2011, 08:49 PM
Silver 2000 M6 with 117K on the body
Engine
Forged LS2
-New GM block
-Used stock crank
-New Eagle H Beams
-New Manley forged flat tops
-New L92's milled .030
-New L76 intake painted black
-FAST 92mm TB
-New timing chain and Billet cam gear
-New LG Motorsports G6X3 cam
-New PAC .660 lift springs
-Comp Cams 7.400 pushrods
-ASP underdrive pulley
-New FTP 98mm lid
-Traction control and cruise control delete
Exhaust
-New Kooks 1 7/8 SS headers
-New TSP ORY
-New Mufflex 4" cat back with straight through Magnaflow single hide away outlet
Clutch and Flywheel
-New F1 racing 15.5 lb chromoly Flywheel
-New Mcloud RST street twin clutch
-New GM hydraulics
Suspension and Drivetrain
-QA1's in the front with 300lbs springs (less than 10K on them)
-Bilstien shocks in back with BMR lowering springs (less 10K)
-Chromoly DS
-Moser 12 bolt with 3.90 gears
-Polished calipers and d/s rotors
-Billingsly LCA's
-Spohn body mount t/a
The trim has been removed and it also has a WS9 outlaw hood. Also just put new deep dish y2ks on it with hoosier radials.
The 3-4 syncro is also going out. The car is completely drivable it jsut grinds sometimes going into 3rd.
If you are interested feel free to PM and I can answer any questions. The engine, exhaust, clutch and flywheel have just over 1500 miles on it. The short block was assembled by Scoggin Dickey Performance in Lubbock Texas.
Asking $11,500
I appologize for no pics, I will try to get some by the weekend.
Engine
Forged LS2
-New GM block
-Used stock crank
-New Eagle H Beams
-FAST 92mm TB
-New FTP 98mm lid
Exhaust
-New TSP ORY
Clutch and Flywheel
-New GM hydraulics
-Chromoly DS
-Billingsly LCA's
Asking $11,500
