Bearings???
I had to change my first set at around 80 k. My second set is already starting to making noise at 105k. I only auto crossed on them 3 times with the new bearings.
I even put in a set of axle shafts cause they were scored. Im hoping the shafts aren't scored again.
Did u do yours yet?
Did u do yours yet?
I've seen new bearings murdered in one hard launch at the drag strip. I've seen other 10-bolts last as much at 200k because it was primarily highway driven. I see in your sig you have the diff cover, that's a big plus, but it really depends on how you've driven your car. If you can rebuilt it yourself, NAPA makes a good kit (stay away from the eBay specials or discount part stores) for around $125 with everything you need. GL.
Mine make a slight sand paper type sound u hear when driving slow 20-40km/h and the windows up with no tunes. U also might hear a hum on the highway if it's quiet in the cabin. I even noticed u could make it hum when cornering on an on ramp when my first set went.
