s-cam
09-25-2011, 04:17 PM
Well after reading thread after thread about low oil pressure and how to resolve it I am now at a crossroads.
I have a texas speed ls3 stroker shortblock with lsa heads and tvs 2300 supercharger in my cts-v. Car ran well and made good power but the oil psi was low. Car maybe has 1000 miles on it since the build that started 2 years ago. I run 20/50 mobil 1 and had put a texas speed ported ls6 oil pump in it. Typical symptoms of great oil psi at cold and at rpm but hot idle it was down as low as 12 psi (at 240 degrees f). I just am scared to drive it with that low of oil pressure. Most information said its the o ring on the oil pump. I bet I read that 50 times so today I pulled the front of the motor apart and after 4 hours of fun on a Sunday I finally got down to the o ring. ITS PERFECT !! not a mark , nick etc.
This leaves me at a crossroads of what to do. Is it worth replacing the oil pump - maybe with a melling high volume pump , button the car back together and hope it holds together? Or do i take it out and tear it down and see if there is a clearance or internal issue. I would not think Texas speed and perf would have assembled it to loose as they have probably done hundreds of builds (maybe thousands). I am just so frusturated as this car has been a money pit and i was ok with that considering what i was trying to build but redoing things really starts to piss me off.
Anyways what i am asking is what would you guys do? Pull it and tear it down or reassemble it with a new oil pump and hope for a small miracle? I am just out of ideas. Any input would be appreciated.
Thanks
Sheldon
Thanks
Sheldon
