05 GTO LS2. 24x reluctor wheel?
Old 09-25-2011, 10:07 PM
Zipty59's Avatar
Default 05 GTO LS2. 24x reluctor wheel?
Ok I know this is a dumb question seeing as Im 99 precent sure I have a 24x reluctor wheel. I'm just double checking before I buy a new motor. I'm looking into buying an LQ4 short block seeing as though I am going to go boosted this winter and the stock LS2 has ALOT of blow by and has been ran hard for the past couple years. The only problem I think I will run into is making the knock sensors work?
Old 09-25-2011, 10:11 PM
JS01's Avatar
You can drill and tap a spot on the side of the block for the knock sensors. And yes all GTO's have a 24x reluctor.
Old 09-26-2011, 07:48 AM
FlamingTA's Avatar
Do you have a 05 GTO and want to run a LQ4? If you do have a 05 GTO then you will want a LY6 block. It's a Gen IV block and will drop right in if you have to go iron. Unless you go for huge boost, the alum block at 4.005" bore will work good. 99.99% of GTO's had the 24x reluctor wheel. From one of the biggest engine builders on this board, he has seen a few 58x GTO's.
Old 09-26-2011, 10:52 AM
Zipty59's Avatar
I guess i didnt explain the whole story im kinda on a budget build aswell. I bought the car for $4,000 and it is clean as hell just has a beat up LS2 in it. I have a local junk yard that will sell me LQ4 long blocks for $600 all day long with a 90 day warranty. I went through this same mess with my 07 NNBS silverado when i bought a GEN III block and figured out the hard way it won't work. Now a GEN IV block like a LY6 has a 58x reluctor wheel. this is where my confussion comes into play The LS2 in my GTO is a GEN IV block but retains the 24x reluctor wheel used in GEN III block.
Old 09-26-2011, 12:02 PM
litle88's Avatar
You can always get the lingenfelter 58x to 24x converter box if your willing to stay aluminum.
Quick Reply: 05 GTO LS2. 24x reluctor wheel?
