Nitrous Oxide - Plug recommendation....
Fast 2010
09-26-2011, 01:58 PM
Not LS based but need to know which plug for a 250 shot. Set up is SBC 377 w/ 13.6:1 . Current plug is an autolite AR3933. Thanks in advance. Sean.
nx346
09-26-2011, 04:12 PM
Not sure about an Autolite, but in an NGK, if it were mine, I'd be looking at a -10 heat range plug in the correct thread and reach for your heads. This should be about right for your compression and shot size.
89pigeontoe
09-26-2011, 08:22 PM
I have a sbf 13:1 on 250 hits I use a ngk -9.
87silverbullet
09-27-2011, 08:44 AM
Yeah but what is the part #.
For example a b8efs in NGK is a 8 heat range plug for an LS motor with a tapered seat.
a r5671A-8 (I think thats the part number) is also an 8 heat range plug but it is a gasket seat plug but it is still an 8.
87silverbullet
09-27-2011, 08:49 AM
Call NGK and ask for Brandon. Very helpful guy and will point you in the right direction for an NGK plug.
Here is a link to the thread I posted.
http://ls1tech.com/forums/nitrous-oxide/1451371-need-some-help-plug-recommendation-non-ls-but-nitrous-fed.html
89pigeontoe
09-27-2011, 08:50 PM
Yea I run the r-15671a-7 n/a then r-15671-9 for nitrous.
1972camarols1
10-04-2011, 05:27 PM
^^ correct
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
