Ron@Vengeance
09-27-2011, 10:13 AM
FORGED LS7 427- FORCED INDUCTION
We just removed this engine from our customers 2007 C6 Z06. The Z06 has 7450 original miles on it. At 6600 miles we removed the engine and built is as listed below. Since then the owner has put 900 miles on the car/engine while building his RHS/All Pro 427 to replace the LS7 with.
FWIW, the Z06 this engine was removed from is IMMACULATE. The car is truly show room condition. The owner is VERY detailed and meticulous with his cars.
Details are as follows:
GM LS7 Block- Fully Machined/Inspected by Proline Race Engines
GM LS7 Crankshaft- 58x Ring- Balanced/Polished by Proline Race Engines
GM Titanium Connecting Rods with Katech Rod Bolts
Diamond Forged Pistons- 23cc DISH (9.25:1 compression)
Total Seal Stainless Ring Pack
GM MLS 7.0 Head Gaskets
GM LS7 Lifters
Comp Cams Trunion Upgrade for OE rockers
GM LS7 Rockers/Bolts/Stands
GM LS7 Oil Pump (Pressure relief spring shimmed .060)
ARP Head Studs
Comp 26926 Dual Valvesprings with TI Retainers
Katech C5R Timing Chain/GM Timing Gears
GM LS7 Cylinder Heads/Stock GM LS7 Valves
GM LS7 Camshaft
Comp Hardened 3/8 Pushrods
GM LS7 Valve covers/gaskets/bolts
All misc bolts/lifter trays/plugs etc installed
The engine has been disassembled/fully inspected/assembled by Proline Race Engines after removal and is ready to go!!!!
Engine will include:
GM LS7 Oil Pan/Gasket/Bolts
GM LS7 front cover Loaded
GM LS7 rear cover Loaded
GM LS7 Intake Manifold/Gaskets/Bolts
GM LS7 DBW Throttlebody
GM LS7 Crankshaft Pulley
Reason for sale: Customer built RHS/All Pro 427.
Please note that this 427 can be installed in other vehicles aside from the C6 Z06. Lingenfelter offers a 24x to 58x converter box for the crankshaft and SD Parts offers a "spacer" for the LS7 crank "snout" to work with other serpentine systems.
This engine can be seen/inspected anytime at Vengeance Racing. Will come with complete build sheet detailing all clearances/specifications.
REDUCED to $10,250.00!!!! (Shipping not included)
Vengeance Racing 440 LS7 Longblock
600/560 with supporting bolt ons
GM LS7 block
Callies 4.125 Crankshaft
Callies Rods
Wiseco Pistons/Rings
ARP Main Studs
TFS 245cc CNC Cylinder Heads
Vengeance Spec Custom Camshaft
Melling Hi Volume Oil pump
Heavy Duty Timing Set
Comp 850-16 Lifters
GM LS2 Lifter Trays
ARP Head Studs
GM MLS Head gaskets
Yella Terra Ultra Lite Roller Rockers
This engine has approximately 5000 miles on it.. All street miles. NA/ No power adders.
$11750.00
http://i88.photobucket.com/albums/k176/VengeanceRacing/LS7440.jpg
GM 427 LS7 Longblock
STOCK
As the title says.. STOCK LS7 longblock. Includes Front/Rear Covers.. Complete Engine including Dry sump oil pump/timing set/cylinder heads/pushrods/rockers
6400 original miles. Still in vehicle.
$10,000.00
http://i88.photobucket.com/albums/k176/VengeanceRacing/StockLS7Longblock.jpg
GM LS7 Lifters
ARP Head Studs
GM LS7 Camshaft
GM LS7 block
Callies Rods
ARP Main Studs
Comp 850-16 Lifters
GM LS2 Lifter Trays
ARP Head Studs
GM MLS Head gaskets
$11750.00
STOCK
$10,000.00
