FS: Gz motorsports lsx vacuum pump kit
Category: Racing Parts
Price: $600
Part Fits: 2010+ Camaro, 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9
LS Engine?: Fits LS Engine
What is your Cell phone number? 314-479-7799 best way to reach me
What is your City? : St. Louis
What is your State? : MO
What is your Zipcode? : 63303
For sale in perfect condition GZ Motorsports Vacum Pump Kit. the link below has more information on it.
http://www.gzmotorsports.com/LSXVPK.html
LS series Chevrolet engines are well known for a lot of blow by and resultant contamination of the intake charge with oil forced past the rings into the combustion chamber. This kit eliminates the PCV valve, allows the rings to seal more effectively and reduces oil contamination of the intake charge which results in added horsepower. A side benefit of the negative crankcase pressure the vacuum pump creates is that it also helps to eliminate unsightly oil leaks.
this is super easy to install and works like a charm! added horsepower and perfect Evac setup!:thumbs:
you will recieve the following:
VP101A Pump
Mounting Brakets
custom designed billet aluminum pulley
Catch Can breather HD
Belt and gilmer belt
custom designed billet replacement oil fill cap (vacuum control)
Katech Billet Belt Tensioner
this comes with all AN fittings needed and hose! simply bolt on and enjoy! :thumbs:
Asking $600 Shipped
