General Maintenance & Repairs - Aftermarket drive belts or GM Belts?
98boxer
09-30-2011, 05:30 PM
I've had bad luck with aftermarket belts, they squeek brand new as soon as i put them on my car but gm belts are quiet.
Anyone recommends an aftermarket drive belt that doesn't squeek? Dont want to pay the 60 bucks for the belt but i just may.
LS6427
09-30-2011, 07:14 PM
My Dayco serpentine belt is like 9 years old and it still looks great, never made a sound.
Schnell
10-01-2011, 03:00 PM
Aftermarket.
Do not buy anything from dealership unless you cannot find anywhere else.
mai krod
10-03-2011, 10:38 AM
yeah dayco makes some pretty solid belts, I've used them on every car I've ever had. never had a problem with one
It'llrun
10-03-2011, 06:39 PM
It's not like GM makes their own belts... Dayco... okay, but I'd certainly consider Gates and Goodyear. Either likely costs more than Dayco, but eh... I prefer them.
LS6427
10-03-2011, 07:18 PM
Just so you all know......the one thing that makes a belt last as long as mine has lasted SO FAR.........is a "fixed tensioner."
The factory tensioner that bounces with a spring......is what stretches out belts and makes them fail WAY WAY before they should. Like mentioned...mine is 9 years old and looks new.....and it hasen't stretched AT ALL, I mean NONE.....my tensioner is still in the exact same position its been set at for the past 9 years.
Check a factory tensioner with a new belt, mark that spot, then check it in a year...it will stretch. That kills belts.
Get a Katech tensioner if you have the money.
98boxer
10-04-2011, 07:49 PM
Thanks for the info, i guess i go with dayco or gates.
Ls6427,
I do have Katech, I will tighten the belt see if that helps.
What actually happened was a co-worker sprayed my engine with water and some cleaning solution and now my camaros belt squeeks. So i want to replace it (it was on the to do list already).
LS6427
10-04-2011, 08:09 PM
Ls6427,
Cool, make sure the belt is tight to 25 ft. lbs.......I do a little more actually, maybe 28.
98boxer
10-06-2011, 07:22 PM
I actually tightened the belt and it continued to squeek into the following day. But today no squeeks, so all is good thanks!
