General LSX Automobile Discussion Non-technical LSX related topics.
Cam/Stall
Old 09-30-2011, 08:24 PM
JcsBlk98z28's Avatar
Exclamation Cam/Stall
So im replacing my oil pump here pretty soon so i figured while im at it why not do a cam. So i started looking around a little and from what i have read on a couple of threads i kinda like the 224/224 .581 .581 cam. So my question is do i need a Stall for that size cam?
Old 09-30-2011, 08:56 PM
ULTIMATEORANGESS's Avatar
Smile
id definitely upgrade to a bigger stall. 3600 would work.
Old 09-30-2011, 09:26 PM
m1a2d3's Avatar
i dont know if you need a stall for that cam but if you have the money buy one. the yank ss3600 is a good choice. might want a 3200 for a daily driver. new cam ,stall and a tune it will be a new car. might want to put in some subframe connectors if you can also.
Old 09-30-2011, 09:32 PM
NVUSZ28's Avatar
Yes you need a stall. I suggest the 3600SS Yank as well. Works great.
Old 10-08-2011, 01:41 PM
98SSClone's Avatar
I don't think it's required, but your car will be a completely different animal with the cam/stall combo compared to just the cam.
Old 10-08-2011, 02:50 PM
blk/slvr02ss's Avatar
No not really but every auto should have one !!!!!
Old 10-08-2011, 02:54 PM
Yeah I talked to my tuner and he said I dont need it.
Old 10-08-2011, 03:04 PM
lemons12's Avatar
Find a new tuner.
It is mandatory.
You will hate driving your car, especially at a stop in D.
I recommend a 3200-3400 ptc since it sounds like you are wanting to stay on the conservative side.
I'll play the game.. Can you? Sure. You can run an ms4 and stock converter... But it will be absolute hell to drive and a complete dog, bolt on cars would beat you.
A converter should be the first mod to an a4, period.
Old 10-08-2011, 03:05 PM
mamead's Avatar
Your probably going to be standing on the brakes at stopsigns to keep the car from rolling. Your tuner might be able to help you out on some of that but get the stall. It's as much of a performance upgrade as a cam.
Old 10-08-2011, 03:13 PM
skopers3's Avatar
Originally Posted by lemons12
Find a new tuner.
It is mandatory.
Why would bolt on cars be faster?
Old 10-08-2011, 03:14 PM
lemons12's Avatar
With a nice coverter, it will give double the performance gains of a cam.
Old 10-08-2011, 03:18 PM
Because the bolt-on car would get out of the hole a lot faster w/ a stall then a cammed car w/ no stall would come out sluggish until it hit its sweet spot !
Old 10-08-2011, 03:22 PM
lemons12's Avatar
Many reasons, a properly set up car with less mods will always be quicker than a poorly set up car with more mods.
Old 10-08-2011, 03:59 PM
Very True i always beat H/C/I cars w/ just my Bolt-On 2002 Camaro SS A4 !!!
Old 10-08-2011, 07:13 PM
senicalj4579's Avatar
Yea, and now you can always destroy H/C/I cars when you get a stall in that vette. It probably already does! lol
Op get a stall at I say at least 3600. My yank ss3600 is perfect for street/strip. Get a cam with that and your car will be a beast!
Old 10-09-2011, 04:57 AM
blake_colvin's Avatar
Saw this and was just wondering if there is a size specific stall to cam ?
like if i got a 233/234 599. 601 cam(just an example) would i have to run a certain size stall (4000 or 3200) for it to be streetable or would pretty much any size work ?
Old 10-09-2011, 02:44 PM
lemons12's Avatar
Anything 3200 or larger would work. But to bring out the potential in the larger cams, you need a larger converter. Ls1s LOVE big converters. Even with a stock cam they will perform better with a 4400 than a 3200.
Anything 23x/23x .600 113 imo requires a MINIMUM of a 3600. If you aren't wanting to go that big on the converter because of the size, you shouldnt be going that big on the cam for the size either. You can run very quick with a 226 cam. My times with a budget setup full weight 2200+da pass barely spinning with a nitrous tune is in sig. I'm not making excuses, just showing what is left with a clean pass. I can still swith to a fast intake setup, 17/8 headers, better merge, better tune, tweak suspension, chrs1313 ram air, ewp, the list goes on. It will run consistent 6.xxs with this cam and heads still full weight and average da. That's a ten second pass fwiw.
If you want to stay around a 3200, I don't recommend it for a few different reasons, you should stay around something similar to Texas speeds 224 cam and smaller.
I see you are in fort Campbell, plenty of guys up there with nice setups from mild to wild, ask if you can get a ride to see how different converters act.
Old 10-10-2011, 12:24 AM
Thanks for the input.. i was hoping to go fairly wild with my set up and im starting to look for an a4 car for it seems like things tend to last longer in the a4 cars like the tranny itself and the 10bolt.. not saying it wont break just seems like it takes more abuse than the m6 cars thats all.
My plans were to go 1 7/8th kooks LT's with true straight pipes, aftermarket LID (depending on car i get), tsp 23X, 23X 115 cam with valve springs and push rods, 373 gears and 31 spline axels, and i was thinking of trying to go with a yank 3600-4000 stall, with 18" c6 wheels with mt et streets.
Oh and a nice nos plate system to boot, prob run a 150shot to start and work my way to a 200shot, try to run deep into the 10's with a 1.60 60ft
I have priced the parts and all that would cost me around 3-4k
Old 10-10-2011, 12:30 AM
lemons12's Avatar
You will end up spending more than that, I would put money on it.. Little things you forget to factor in add up QUICK!!!
Also.. With that setup on motor you should cut a 1.5X short times... Bottom 1.4s on a decent nitrous hit.
Factor in suspension, you will need it.
Old 10-10-2011, 12:49 AM
Mazzenger's Avatar
I had a 221/221 cam long time ago with stock stall. It was a turd. Pulled slightly worse times and no better mph than before the cam. (huge bogging issues)
Month later put in a SY3500 and car gained 4mph and dropped about a second.
Don't skimp on the converter.
