Cam's done, Need shorter Belt to fit UD pulley...
Old 10-01-2011, 09:13 AM
USMC5811's Avatar
Default Cam's done, Need shorter Belt to fit UD pulley...
The cams finally done and everything is running great....except...since I put an UD pulley on my serpentine belt no longer fits. Ordered one from Maryland Speed but it will be in sometime next week. Does anybody know of another cars belt that I could use that would be 3-4 inches shorter than mine that I could pick up from advanced/autozone in the meantime.... so that i can have it drive....
Old 10-01-2011, 10:29 AM
PontiacFan's Avatar
Belt numbers required are scattered all over this website, ...
Do you know the current part number?
Then choose one a bit shorter.
The belt numbers are generally their length.
Any local auto parts store should have your current stock part number required & should be able to share one that is shorter.
Old 10-01-2011, 10:32 AM
5.0 LsX's Avatar
If the person behind the counter at a parts store knows what they are doing, juss tell them you need a belt that much shorter than your stock one...I can get you a gates/goodyear part number later today if you want to pm me..
Old 10-01-2011, 10:36 AM
PontiacFan's Avatar
Found my SLP UnderDrive Pulley Installation Document.
This:
NOTE: Requires 2 new belts (Gates #K060763 and #K040378 or equivalent,
not included). For LS1 F-Bodies only.
