Noob, Headers and AIR tubes
I have a 2002 m6 TA WS6, I'm planning to get LT headers race style, what do I do to get rid off the AIR tubes and hoses that connects with the fuel EVAP, Should I get rid off the hole thing with the hoses or just the part that connect with the headers do I block the hoses off??? I'm thinking of Frost mail order tune my PCM after since I'm in Germany.
i completly forgot about AIR when i did my header install, so you know what i did? removed the AIR tubes, cut the vacuum hoses off and removed the associated hardware, ie, the air pump and the black cylinder hanging out by your intake manifold on the right sde in the back. i then used duct tape to block off the connection to the slp lid for AIR. yea it throws a code but started right up and never have had an issue. you will need the AIR codes tuned out to not throw a code. in other words cut that crap out AIR is completly not needed
Slp has a ir hose cap for the lid get vacccum hose cas for the thing in the back for the air then get under your car on the drivers side and take off the black flap the one you take off to change blinker bulbs and theres a big a$$ fan thing take it off and pull out all of the hose and delete your code it gives. The code doesn't do anything to your car
Mail order tune would be the way to go if you're not going to have someone physically tune it for you, after you've done major mods. (key word: major) There are a couple of places in Stuttgart, München, and Köln to get it tuned, but I would never trust a German to tune an American LS1, when he's been dealing with BMW's all day long.
That's my 0.02¢
That's my 0.02¢
That's my 0.02¢
That's my 0.02¢
alright you have to go to your drivers side and remove the splash guards. there is a big fan 4 bolts to unbolt it. take off the hose to the lid and go to the back of intake and remove the other fan looking thing and get vaccum caps from autozone etc. then pull out all of the tubing. then all that is left is what is on the manifolds. you have to buy air delete covers for the manifolds unless your getting off road headers hope this helps.
The vacuum pump for the air system is under the driver side behind the bumper/fender.The hose runs up the driver side under the hood near the fender.It all disconnects easy.It only runs the first few minutes to warm the cats up
FINALLY GOT RID OF IT, HERE ARE SOME PICS, LET ME KNOW IF I'M MISSING ANYTHING PLEASE!!!
HERE IS WHAT YOU BLOCK WITH A VACUUM CAP
[IMG] Uploaded with ImageShack.us[/IMG]
INSIDE HERE IS THE VACUUM PUMP.
THIS IS HOW IT LOOKS LIKE FROM THE BOTTOM.
GOT THAT CRAP OUT, FYI 4 BOLTS 10MM SIZE, CAN'T MISS IT!
WHAT DO I DO WITH THIS??? JUST TOOK IT UP?
THIS IS WHAT I GOT RID OFF, DID I MISS ANYTHING?, HOW DID I DO, PLEASE COMMENT!
[QUOTE=Ronny_02_WS6;15510225]FINALLY GOT RID OF IT, HERE ARE SOME PICS, LET ME KNOW IF I'M MISSING ANYTHING PLEASE!!!
WHAT IS THIS FOR???
This is vacume supply for your power brakes.
WHAT IS THIS FOR???
