Porter Cable?
Porter Cable?
Hello everyone!
Whenever anyone is on the subject of detailing a car, more often than not people mention using a porter cable. What is this? Isn't Porter Cable a brand and the tool is actually called a rotary buffer?
Sorry, Im just confused on what people are referring to.
Also where can I get one of these Porter Cables at and how much are they?
Thanks
Thanks
From detailed image.
Porter Cable 7424 XP
The Porter Cable 7424 XP is often referred to as the standard in the auto detailing industry. We've yet to come across a buffer at a lower price point that has enough power to effectively break down polishes like the Porter Cable 7424 XP can. This is on of the main reasons why the PC 7424XP is our best selling buffer.
The PC 7424XP is one of the first buffers detailing enthusiasts gravitate to for two main reasons, the lower price point and minimal risk of damaging your paint. The PC 7424 XP is a random orbital buffer, which means it oscillates rather than spins. This helps reduce the amount of heat generated on the paint and is very safe to use. Even at full speed, the risk of damaging your paint is very minimal.
Pros:
Low cost compared to other quality buffers on the market
Minimal risk for damaging your paint, even at full speed
Easy to control and maneuver
Various backing plates available for different sized pads
Cons:
Can easily bog down when applying pressure due to the small motor
Has it's limitations on deeper imperfections
Very time consuming to achieve professional results
Backing plate not included
Pros:
Cons:
http://www.autogeek.net/po.html
Here is a whole bunch of them...they have 10-15% discounts to...I bought mine here and its great
Check out some of these vids
http://www.autogeek.net/dual-action-polisher.html
http://www.autogeek.net/showcargarage.html
IMO if you are just starting out you cannot go wrong with the PC for the price. Depending on how bad of shape your paint is in you will be able to get some pretty good results out of it. If you want to spend a little more i would look at the flex 3401, very nice unit and has the ability to create a little more heat then the PC which results in more cutting power it also has less vibration and imo is easier to use then the PC. I can get just about as good of results with the flex as i can with my rotary, the flex just takes more time to get their. A lot depends on choosing the correct compound and pad combination for the condition of your paint as well.
Thanks for all the info guys. I really wanna get one of these!!
