? on alternator bracket for LS1 into C2 corvtte
Old 10-02-2011, 02:19 PM
jdeuel87's Avatar
Default ? on alternator bracket for LS1 into C2 corvtte
Anyone able to tell me if the stock alternator bracket an location on the lower drivers side will clear if putting into C2/C3 corvette standard frame? Thanks
Old 10-02-2011, 02:32 PM
Gordonm's Avatar
The alternator is not the problem The PS pump if you are running PS wil lhit the upper control arm. Not even close to fitting. I am running a smaller PS pump pulley that works. It is still close but clears.
Old 10-02-2011, 02:55 PM
garys 68's Avatar
Are you using covette or f body accessories? Also, which motor mount plates?
Old 10-02-2011, 03:20 PM
jdeuel87's Avatar
using S&P motor mounts, no power steering/ac, will only have alternator, want to use f-body alternator bracket...Thanks
