General LSX Automobile Discussion Non-technical LSX related topics.
Heads and Cam recommendations
Old 10-02-2011, 08:56 PM
slp99ws6's Avatar
Default Heads and Cam recommendations
I have a 99 ws.6 trans am with full slp exhaust and just bought a used ls6 intake for it but am looking for heads and cam to get into the low to mid 400 horse power range with what do u think about the prc 2.5 5.3 heads and maybe the ms3 cam or if not what do u recommend thanks
Old 10-02-2011, 08:59 PM
Camaro_94's Avatar
I'm running new era's street sweeper HT cam and made 440rwhp on a 95 degree day with full boltons and ported LS6 heads. The cam specs were 228/232.
Old 10-03-2011, 12:37 AM
JOHN STEPHENS's Avatar
I have the torquer V3 cam (specs are in sig) and the PRC 2.5 LS6 heads. The 5.3 heads were an option because you gain a little compression. But what i found out was the ports on the LS6 heads are straighter and outflow the 5.3 heads. All in all i love my setup.
Old 10-03-2011, 01:21 AM
NVUSZ28's Avatar
MS4 Cam only will get you 400 RWHP.
Old 10-04-2011, 06:02 AM
Orange Juice's Avatar
When deciding on a cam you need to consider driveability. Do you still have the stock rear gear?
Old 10-04-2011, 06:32 AM
SOMbitch's Avatar
For basically the same money do a ported 243/799 head with stock size valves and you will be better off...
Old 10-04-2011, 06:02 PM
slp99ws6's Avatar
i have 3.73's
Old 10-04-2011, 09:58 PM
garygnu's Avatar
243/799 stock heads and big cam or ported heads and a smaller cam,which path cost less and is more street friendly ?talk to Patrick-G for a proven combo.what trans and rear gears do you have ?read and ask more questions to learn about all the other hiPro parts you will need to consider buying to make the total combo work and kick-A.you will need bigger injectors and a good tune .you will also need a good clutch or stall converter,and good rear gears..check the dyno section for some ideas.TSP heads and a EPS cam,or look at a vengeance racing combo.
Old 10-08-2011, 08:11 AM
RAMJET5's Avatar
You say 228/232 for the duration on your cam is that advertised duration or is that at .050 lift. What is the lift on your cam? this is intended for camaro 94
Old 10-08-2011, 12:35 PM
Camaro_94's Avatar
228/232 .600/.612 lift and 111lsa. VERY streetablr and makes good power.
Old 10-08-2011, 01:38 PM
98SSClone's Avatar
Thunder Racing has some nice packages for a H/C setup with Patriot Heads and one of their cams.
Old 10-08-2011, 03:14 PM
blk/slvr02ss's Avatar
I Would do sum LS-6 Heads and ask Patrick G what cam he recommends !
Old 10-09-2011, 11:29 AM
NY02ws6's Avatar
I would definitely recommend looking into a Vengeance racing kit, Ron was really helpful when I was looking for a top end kit
Old 10-10-2011, 10:07 AM
Kevin@Vengeance's Avatar
Check the link out below. This has our budget heads/cam kit and our all out heads/cam kit but we have several kits in between to fit your specific needs and price range. Give me a call here at the shop or shoot me a PM to discuss in detail. Thanks!!
https://ls1tech.com/forums/sponsor-s...-cam-kits.html
