MAF Sensor cutting out at high RPM HELP
I have a LS2 in my G35 coupe. When on the dyno the MAF is cutting out around 6K. Falls completely flat. Trying to get a few ideas, maybe someone else has had this issue. Its only at high RPM. Thinking ground maybe, I have ordered a new MAF but really don't think thats the problem.
I took it down untill I had got the official numbers from the dyno since the children on my350z gave me so much **** about posting 500 rwhp without a dyno. I don't even post over there anymore. I did dyno 474 RWHP and 430 Torq. I brought it to the track with stock tires ( 8" wide ) and spun all the way through 4th. Second pass I started in second and hit 13.01 @ 128 MPH. .538 Reaction time and I think it was 1.98 60'. I have just ordered new wheels and should see low 11 or high 10 giving my times. If you have any questions durring your build I help eveyone out doing the swap. 225-305-7015. There were a lot of trial and errors getting everything working perfectly. I'll post up a write up later today and some more pictures.
I was gonna drop the MAF and go SD tune but there were a few problems as well. I'm gonna try the new MAF if that doesn't work , well the fun part starts.
