Will a '97 rearend fit my '00?
Old 10-02-2011, 09:36 PM
Y2K_Camaro's Avatar
Default Will a '97 rearend fit my '00?
My buddy pulled the 9" he had in his '97 Camaro, he asked me if I wanted it. Will a 9" made to bolt to a '97 bolt right up to my '00 Camaro? Will I need to get a shorter or longer driveshaft? What about U joints, do I need new better ones?
Old 10-04-2011, 06:09 AM
LS1Tech Sponsor
Bob@BruteSpeed's Avatar
Yes it will fit your Camaro. You will need a one inch longer driveshaft. http://shop.brutespeed.com/PST-DRA35...-PST-DRA35.htm You'll have to find out if the yoke on the nine inch is a 1350, or a smaller size to determine which U Joint you'll need. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old 10-04-2011, 05:41 PM
1972camarols1's Avatar
^^ correct
Old 10-04-2011, 06:50 PM
Deviant LS1's Avatar
If you want to keep LS1 brakes and the LS1 parking brake setup you'll need to swap your backing plates. Depending on what channel abs setup the 97 had you'll might have to change a few things to make everything work in your channel car.
Old 10-08-2011, 12:07 AM
Y2K_Camaro's Avatar
Ok, thank you very much for the info. Hopefully this swap will go over well.
