Drag Racing Results - 1/8 mile help
View Full Version : 1/8 mile help
SLP4CamaroSS
10-02-2011, 09:42 PM
went to the track friday night lil disappointed dont know if it was the tires/car/track... i think i should be running faster.I do have 8yr old pretty bold et streets on 16inch rims which could be the problem. Launching from 4500-5000rpms (quick release not side step it) about 18-22psi in the tires (all the same result). Takes off it would spin hard fish tail to the left then take off. the track wasnt prepped at all. need some input thanks
60ft 1.82
330ft 5.14
1/8et 7.94
mph 88.11
mods
fast92/92
g5x3 112lsa
svo30
pacesetter headers
magnaflow exhaust
underdrive pulley
TDP stage 3 clutch
12bolt 3.73
suspension
lg adj lca/phb
spohn tunnel mount adj ta
umi subframes
thunderstruck507
10-03-2011, 08:56 AM
You are running pretty much what I do. I would expect your combo to trap higher with the manual trans (90-92mph).
It's a good starting point. Tune up if it hasn't had one lately, maybe some fine tuning, and honing of the driving skills and where it wants to be shifted and you should be golden.
Camaro Z
10-03-2011, 09:16 AM
What were the weather conditions like? I would expect your trap to be in the 90's regardless of track prep. What RPM were going through the traps at (just curious)?
SLP4CamaroSS
10-03-2011, 10:15 AM
weather i dont rember the exact temp but it was in the 50s/5500rpms trap .... im going to change the plugs.... havent done it in forever i rarley drive the car so my 2nd to 3rd shift prob needs some loving
slayer performance
10-03-2011, 10:22 AM
get new tires.....
sleeper101
10-03-2011, 11:20 AM
You can cut that wheel spin down by getting some fresh tires or by going to a taller gear would help also. Like a 3.23 you would also pick up several mph. A taller tire also might help you.
Camaro Z
10-03-2011, 11:37 AM
He's an M6, 4.10's are about perfect for the 1/8th mile. My car goes through the traps at 6400 or so in 3rd at 93-94 mph with a 26" tire. I'd say you're not too far off, some drag wheels would help you quite a bit as well vs. the 16" stockers.
SuperSlow02
10-03-2011, 12:01 PM
Deffinently low on mph....but get some new slicks and try again
