Tools & Fabrication - Straight CO2 for mig?
View Full Version : Straight CO2 for mig?
2nd Gen Fl 'bird
10-03-2011, 10:36 AM
Bought a mig and came with big bottle of straight co2. Use it or get the argon/co2 mix? The guy was telling me it works the same. Don't want to fight with the weld from the start if the co2 is not optimum.
Chevyboy82188
10-03-2011, 11:41 AM
The welds with argon mix will look much better.
G-Body
10-04-2011, 12:40 AM
It depends what you are trying to weld. If its sheetmetal get the argon/c02 mix. The straight C02 will burn hotter so if its sheetmetal it will make it even easier to burn through. If its thicker metal you will get more penetration with straight c02, but the welds won`t look quite as pretty.
2nd Gen Fl 'bird
10-04-2011, 08:49 AM
Basically welding brackets, exhaust tubing(which is thin walled). We'll see how it goes. Good to know co2 is better for penetration. Thanks.
01ssreda4
10-06-2011, 02:08 AM
Each bottle blend effects the weld differently. When I welded for a living we did mostly heavier stuff and I always used the 75/25 and it always worked well. I'm pretty sure at the exhaust shops and stuff they use a different blend, thinner wire, and they can lay down fat/wide beads on thin exhaust pipe because the penetration is shallow with their setup.
davo3000
10-06-2011, 09:36 AM
it all depends on which wire you are using
davo3000
10-06-2011, 09:38 AM
for example if you are using a stainless steel solid core wire ,tri-mix is recomended.
