wicked383lt1
10-03-2011, 12:12 PM
I have a 327 in my 69 nova but when it heats up it seem to loose oil pressure and bogs out big time...please all advise is needed.
93 LT1 Vette
10-03-2011, 04:02 PM
What are your gauges reading? Has there been a major change in oil pressure lately? Is the motor running hotter than usual? Any new sounds coming from the motor?
64nova_wagon
10-27-2011, 02:13 PM
Is this a rebuild? My 68 camaro was 100 stock untill this summer. It leaked oil and seemed sluggish. I pulled the engine thinking I would reseal it, then.. Wham. Found out the timing chain was touching when I pulled inward, the cam had 5 lobes wore off. Having bad cam bearings will cause oild to go away when it heats up. Im sure if its never been touched you will need a oil pump and chain.
