Small Block & Big Block Chevy Specific - 1000 HP sbc
shaq_2500
10-05-2011, 05:19 AM
If u were doing a 1000hp sbc. What motor setup would u use. It will be a street/strip setup mostly strip. Just want to make a few blocks on a nice Sunday
Motor size
Compression ratio
stumprrp
10-05-2011, 09:39 AM
1000 hp NA?? well if thats the case at least 440ci with 15:1 on alky and SB2.2 heads man.
Darracq
10-05-2011, 03:13 PM
Thats going to cost a ton to do NA and will be working on it all the time, I would do a big block myself.
shaq_2500
10-05-2011, 03:21 PM
Want the big block cost more
flyin
10-05-2011, 04:26 PM
no the big block will make more power at less cost overall.
ANYTHING 1000hp n/a will cost you a lot of $$$$$. Easy $10k for either small or big block
You want a "budget" 1000hp, build a turbo car
Bowlson
10-05-2011, 09:07 PM
A big block will weigh more than a small block
02SSISFUN
10-05-2011, 10:18 PM
why do you want a 1000 horse motor? youll never be able to use even half of it on the street..
shaq_2500
10-07-2011, 10:01 AM
the car want be race on the street but i have never liked a trailer queen. its going in a streetable back half car> it dont have to be a 1000hp on motor cause it will for sure have some nitrous.
TheGreat4.8
10-07-2011, 04:48 PM
go twin turbo!
Faught
10-07-2011, 07:50 PM
i would get a nelson racing engine, but if i were to build one i would do a TT 408 or something like that.
LSCustoms
10-08-2011, 03:18 PM
well, whats your budget and what kind of car is this going in?
LSCustoms
10-08-2011, 03:28 PM
in my opinion the most budget friendly street build, would be a 5.3 with either a turbo or procharger...
http://www.carcraft.com/techarticles/ccrp_1102_chevrolet_5_3l_ls_budget_engine_build/viewall.html
to do this NA will be quite a bit to get a small block up to par, enough to handle a big shot of nitrous... there r several people pushing the limits of the $500 5.3 junkyard motors...
to build an equivalent, lets say 406 sbc and get it to 600+ NA hp, with all the crazy internals/heads/etc. is costly. you will more than likely be paying around 1600 just for the heads... let alone the bottom end, maybe concrete the block, etc...
flyin
10-08-2011, 06:18 PM
he wouldn't be posting in the SBC & BBC section if he wanted an LS based motor...geez people
If you are set on a small block chevy, to get 1000hp even with n2o is going to cost you a very pretty penny. So to help you, we need to approximately know what budget is.
My advise to you is go big block. And I mean like a 540 cubic inch big block. Get a set of AFR 335cc heads and make an easy 700+hp n/a and make up the rest with n2o
LSCustoms
10-08-2011, 06:34 PM
My advise to you is go big block. And I mean like a 540 cubic inch big block. Get a set of AFR 335cc heads and make 700+hp n/a and make up the rest with n2o
hmmm. i thought that it would apply, being that i consider a 5.3 or 6.0 a sbc motor
