How do i remove my rear without a lift?
Old 10-05-2011, 07:40 PM
Floorman279's Avatar
Default How do i remove my rear without a lift?
i searched but found nothing......getting my s60 in a few weeks and have a forklift, plenty of jacks, and a few stands.....how easy will this be and is there a certain order i remove everything? the car is a 98 z28 any basic how to advice/steps would be nice...thanks
Old 10-05-2011, 10:57 PM
01ssreda4's Avatar
Jack the rear up, put the jackstands under the rear sub-frame while the rear hangs down. Pretty simple and straight-forward.
Old 10-05-2011, 11:24 PM
mesterious's Avatar
+1 having someone helping makes it a lot easier also...
Old 10-06-2011, 02:56 PM
Ok...thanks
Old 10-06-2011, 04:44 PM
SmokedOutZ28's Avatar
+ 1 to that! I had a few people over helping me get mine in and made it pretty simple.
Old 10-07-2011, 12:44 AM
01ssreda4's Avatar
Don't need an extra person. Leave the LCAs attached and the rear can be swung down to the ground. Once the weight is resting securely, you can unbolt them and roll it out of the way. I have found it is good to have a furniture dolly under it so you can roll it, though I have drug mine out on the concrete before.
Old 10-07-2011, 07:31 AM
Kleeborp the Moderator™
MeentSS02's Avatar
Carefully? That's how I removed mine without a lift - I was by myself in my little 1 car garage at the time. The 10-bolt is light enough that it can be picked up and carried...the Dana 60 (and even my 12-bolt for that matter), not so much.
Old 10-07-2011, 12:48 PM
blackls1ta00's Avatar
i did mine myself in a small one car garage with 2 jack stands on the frame connectors and a 3ton jack,its not bad at all by yourself.
Old 10-07-2011, 01:47 PM
need4fun2469's Avatar
I put jack stands under the subframe and lowered the rearend onto a floor jack and wheeled it out when everything was unbolted from it.
I was by myself.
Old 10-07-2011, 07:01 PM
i appreciate all the responses.....feel better about doing it now
Old 10-08-2011, 05:39 PM
O and a dumb question......do i tighten all my bolts as tight as i can with my hands
Old 10-08-2011, 06:19 PM
01ssreda4's Avatar
Basically yes.
Though I'm unfamiliar with the s60, we have found that the 12 bolt, 9 inch, and 10 bolt all weigh relatively the same, about 200 pounds. We are referring to Moser aftermarket rears though.
Old 10-10-2011, 08:02 AM
runtwrestlin's Avatar
Yea, i picked up my 10bolt by myself, no problem. I tried to do the same with the S60 just to see, and I quickly decided not to try (maybe it was the snapping in my back that warned me).
There are two bolts that you aren't supposed to make as tight as you can. I don't remember which ones or the specs, so I'm not much help there. But I rmr reading something about a specific torque specification for the new torque arm. The instructions said not to over-tighten them because they are pivot points.
When getting some of the brake fittings undone you may want to use penetrating oil and a heat gun (i used a hair dryer) to help loosen them up.
Old 10-10-2011, 08:32 AM
69TA's Avatar
when you go to put the rear back in.
make sure you put the tq arm bolts and nuts on the S60 rear first
before you go start doing all the other stuff
