Cruse control stopped working after clutch install?
Old 10-06-2011, 11:27 AM
mike c.'s Avatar
Default Cruse control stopped working after clutch install?
got the new clutch in and the cruse has not worked since. This happened once before and the i took it back to the shop(they r closed now) and the guy went under my dast,turned something and it worked. This new shop can't figure it out even know i tried to tell them the other shop went in the car under the dash. Any thoughts??? Thanks, mike c.
Old 10-06-2011, 01:25 PM
MikeMs01TA's Avatar
There's a switch that the clutch rests against when you aren't pressing it. Just turn it until it's pressed enough to work
Old 10-06-2011, 10:53 PM
mike c.'s Avatar
where is it at and what should it look like??
Old 10-06-2011, 11:54 PM
Deviant LS1's Avatar
It's under the dash up where the pedal assembly is. You'll have to remove lower part of the dash that covers the steering column and has the hatch switch. You'll also have to pull the black plastic cover that sits above the pedals around the OBDII Port.
This is what it looks like.
You have to unplug it and turn the switch until the plunger makes full contact and is compressed. Check your brake switch also while you're under there. That would also stop your cruise control from working and it's right next to the clutch switch.
Old 10-09-2011, 10:25 PM
mike c.'s Avatar
Thanks,man.
Quick Reply: Cruse control stopped working after clutch install?
