Fueling & Injection - will aeromotive 13101 fpr work with dual intank walbros instead of an a1000
AAK z28
10-06-2011, 12:57 PM
I was wondering if aeromotive 13101 boost referenced fuel pressure regulator will work with dual intank walbros instead of an a1000. When you look it up it says its specifically designed for an a1000 but will it work with my intank pumps. I got it for free from a friend.
pdasterly
10-06-2011, 07:22 PM
you would have to remove factory regulator from tank, block old return and run new line to tank
AAK z28
10-06-2011, 09:39 PM
I have all new lines -10an feed line and -10an return with Wilson fuel rails with -10an crossover. Im just trying to make sure it will work with intank pumps not just an a1000. Anyone else?
AAK z28
10-07-2011, 09:57 AM
Anyone ?
TPIIROC
10-07-2011, 10:11 AM
Don't see why it wouldn't. I am planning on using the same regulator with my set up of 044 pumps.
Cam72aro
10-09-2011, 10:28 AM
Yes it will work. I am running dual intank walbros with the aeromotive boost referenced regulator on the rail. Pressure is pressure, it doesn't know if the pump is in the tank or outside the tank.
Ollie8974
10-09-2011, 01:04 PM
Why would you have to run a new return line?
Remove the regulator and use the stock return line
Strokinit383
10-10-2011, 02:18 PM
I plan on running the same setup as well. Im going to use my stock feed as a return and plumb another line for a larger feed line.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
