Any e85 ls1's in here?
there are tons of people running e85. your tuner buddy doesn't like it b/c of the variances in blends that one could get at the pump. and for the average joe who doesn't have a wideband they wont know.
if you have a wideband on the car i dont see the harm in it. also if you're not running your timing on the ragged edge i also dont see a problem with it...
but what do i know. your tuner buddy is the expert.
the benefit of E85 is its convenience. When I go out in kill mode 104oct isn’t going to cut it. At that point I could buy a higher corn fuel, like Scott is probably doing. But now the convenience is gone. So I’ll go with C16.
Corn fuel is cheaper, but if I’ve spent thousands upon thousands of dollars on my car, I’m not going to penny pinch on some g’damn gas.
That’s just me. Do what you want
I had been running mine on Q, which is the worst fuel for FI with air to air....and too many variables are going to change to compare power between the different fuels.
I'll probably run a drum of e85 through it and then change it to something else.
