Kevin@Vengeance
10-07-2011, 04:47 PM
Vengeance Racing Builds HufferSS’s
2011 Superchaged Synergy Green Camaro SS
This Build Consists of the Following Modifications:
· Whipple 2.9L Supercharger
· 3.5” Pulley with Carbon Jack shaft cover and inlet tube
· LPE Twin in Tank Fuel System
· 60lb injectors flowed by FIC
· Vengeance Racing Custom Stage II Blower Camshaft
· TEA Dual Gold Spring Kit with Ti Retainers
· Comp 7.400 Hardened Pushrods
· Katech C5R Timing Chain
· Meiling Hi Volume Oil Pump
· Comp Trunion Kit
· Snow Performance Methonal Injection System
· 180* thermostat
· Pfadt Lowering Springs
· Pfadt Performance Sway Bars
· Pfadt Rear Tie Rods with Bushings
· Pfadt Rear Trailing Arms with Bushings
· Pfadt Solid Rear Subframe Busings
· Pfadt Polyurethane Diff Bushings
· RPS/Hendrix Engineering Street Twin Carbon Slayer Edition Clutch
· Hendrix Engineering 9” Conversion with Strange 3rd Member with 3.89 Gears
· MGW Short Throw Shifter with Race Knob
· LPE LNC 2000 Two Step
· SJM Line Lock
· Vengeance Racing Custom Valve Covers with Coil Relocation Kit
· Autometer Carbon Fuel Pressure and Boost Gauges
670 RWHP 607 RWTQ.....550 RWTQ @ 2600 RPM
http://www.camaro5.com/forums/images/statusicon/wol_error.gifThis image has been resized. Click this bar to view the full image. The original image is sized 1023x788 and weights 105KB.http://i1107.photobucket.com/albums/h389/KEVINatVENGEANCE/BillMallet2011CamaroWhippleDyno.jpg
http://fototime.com/5591de90a808fc8/standard.jpg%5b
http://fototime.com/71C44CEDE06AEE7/standard.jpg
Idle/Rev Video
http://www.youtube.com/watch?v=41SuGHez15Q
· Comp Trunion Kit
· 180* thermostat
· SJM Line Lock
Idle/Rev Video
