McLeod Street Twin on Stock Hydraulics?
We highly recommend using our large bore master cylinder with our LT-1 & LS-1 Street Twin so much so that if you use the OEM master and burn up the clutch it will void any warranty with McLeod.
hold on... the street twin is different from the rst/rxt correct? im running rxt and i remember you saying to use stock master... is that correct? i forget that mcleod has a different twins
