knock sensor removel...
Please excuse me if I'm posting In The wrong place but I'm workin on a 02 tahoe w/5.3 motor and need to replace the number 2 ks. The problem I'm having is the old one wont come out. I'm tryin to remove it using a 21mm socket but the part where the socket goes onto has stripped and rounded. I've tried using an extractor kit with a 17 and 19 mm extractor but its starting to get worse. Can anybody help. Don't really care what car it is as long as its the same setup it could help me in this situation... Thanks in advance...
Yea, its rusted pretty good. I've tried the smaller socket but didn't work which brought me to to extractor idea which isn't really helping cause I'm using a 17mm now and still nothin... Can I take the valley cover off and get to it easier?
Yes, the valley can come off with the sensors still screwed into the block,, after that you may be able to grab them with a set of vise grips or something... When You put new knock sensors in, put some antisieze on the threads, and they only torque to 11 Ft. lbs. Hope this helps
Seems like the holes at the bottom of mine were plenty big enough.
The rear rubber gasket on mine actually stuck on the post after I removed the rear knock sensor.
It would take some prying, but pretty sure you could get it off with the gaskets and knock sensors in place.
