Anyone using LS7 heads, without a cam thats on a LS7 cam base circle
Changing over to some LS7 ported heads. Is there any resin that i need to use a LS7 base circle cam?
Only thing iv seen is so u can use the LS7 pushrods?
But i think i going to have to get custom pushrods do to the morel link bar lifters anyway im running anyway.
anyone seen a resin to use the LS7 style cams?
There is no reason. Only reason would be to re-use LS7 pushrods, which you can't do if you're going to use Morel-Linkbar lifters. You would have to get new pushrods anyway.
No problems, go for it, measure out your correct pushrod length with the correct pre-load for those lifters and you'll be good to go.
Have fun!
Have fun!
