4th gear grind after Tick MC and mobil 1 ATF
I just installed my Tick MC and all the gears go in and out much smoother than before, however 4th gear grinds. It has always had a slight scratch/grind at high rpm, but I blamed the stock MC on that after doing some reading. Now the scratch/grind seems to be worse than before. I bench bled the system before I put it in, but still have yet to bleed it after the install. I'm sure there may be a little air in the system but not sure this is the problem as all the other gears work smoothly. It does this both on the 3-4 up-shift and 5-4 down-shift. Only other variable is that I changed the tranny fluid to Mobil 1 ATF a day before I did the MC, but never did any high rpm shifting so not sure if this had a negative effect. Possible air causing grind from not engaging clutch all the way? Time for rebuild? Synthetic ATF causing it to act up? Any help would be appreciated! thanks!
Its strange because it used to occasionally grind going into 3rd gear, but after MC install it doesn't at all.
