98 Z28 tuning problems
Ok I have finally got to the motor after suspension and driveline improvements. So I just wanted a cam only car. So in goes pro products 96mm intake, throttlebody, and fuel rails, walbro 255 pump, Bosch 30 lb injectors(36 lb@58psi), MSD BlasterCoils, and Tick Polluter Cam. Everything going good til tuning process. Car hesitates (damn near dies) from 2k-26 rpms then at 27ish BAM! Full power like I'm trying to launch at the track. Apparently a 98s pcm is untunable with what I gave put into the car? Can someone verify this for me? Because the only options they have given me are 1) get 00-02 pcm and re-pin it for my 98 harness or 2) get 00-02 pcm with wiring harness and install it all? As for now car is parked and that isn't cool. Any ideas please!?
